HP Envy dv6-7363cl Wi-fi Card Replacement
  1. HP Envy dv6-7363cl Wi-fi Card Replacement, Battery: step 1, image 1 of 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Wi-fi Card Replacement: step 2, image 1 of 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Wi-fi Card Replacement: step 3, image 1 of 2 HP Envy dv6-7363cl Wi-fi Card Replacement: step 3, image 2 of 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Wi-fi Card Replacement, Wi-Fi Card: step 4, image 1 of 1
    • After removing the battery, remove the circled screw.
  5. HP Envy dv6-7363cl Wi-fi Card Replacement: step 5, image 1 of 1
    • Remove the back cover.
  6. HP Envy dv6-7363cl Wi-fi Card Replacement: step 6, image 1 of 1
    • With the back cover removed, locate the Wi-Fi card which is positioned next to the Beats logo.
  7. HP Envy dv6-7363cl Wi-fi Card Replacement: step 7, image 1 of 2 HP Envy dv6-7363cl Wi-fi Card Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully remove gold-headed, black wires from Wi-Fi card with tweezers.
  8. HP Envy dv6-7363cl Wi-fi Card Replacement: step 8, image 1 of 2 HP Envy dv6-7363cl Wi-fi Card Replacement: step 8, image 2 of 2
    • After removing wires, remove circled screws from card.
    • Note: Laptop shown only has one screw holding in Wi-Fi card. Some models may have both.
  9. HP Envy dv6-7363cl Wi-fi Card Replacement: step 9, image 1 of 2 HP Envy dv6-7363cl Wi-fi Card Replacement: step 9, image 2 of 2
    • Wi-Fi card will raise out of device when screw is removed.
    • Gently pull card to the right to remove from device.
dylananthony
564 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 416
