HP Envy dv7t-7200 Optical Disc Drive Replacement
  1. HP Envy dv7t-7200 Optical Disc Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Optical Disc Drive Replacement: step 2, image 1 of 3 HP Envy dv7t-7200 Optical Disc Drive Replacement: step 2, image 2 of 3 HP Envy dv7t-7200 Optical Disc Drive Replacement: step 2, image 3 of 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Optical Disc Drive Replacement: step 3, image 1 of 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Optical Disc Drive Replacement, Service Cover: step 4, image 1 of 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Optical Disc Drive Replacement: step 5, image 1 of 2 HP Envy dv7t-7200 Optical Disc Drive Replacement: step 5, image 2 of 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Optical Disc Drive Replacement, Optical Disc Drive: step 6, image 1 of 1
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  7. HP Envy dv7t-7200 Optical Disc Drive Replacement: step 7, image 1 of 2 HP Envy dv7t-7200 Optical Disc Drive Replacement: step 7, image 2 of 2
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  8. HP Envy dv7t-7200 Optical Disc Drive Replacement: step 8, image 1 of 2 HP Envy dv7t-7200 Optical Disc Drive Replacement: step 8, image 2 of 2
    • Slide the disk drive out of the laptop.
Krystal
882 Reputation
8 Guides authored
UW Tacoma, Team S3-G3, Liner Fall 2017 Member of UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 135
