HP Envy m6-k022dx RAM Replacement
  1. HP Envy m6-k022dx RAM Replacement, Lower Case: step 1, image 1 of 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx RAM Replacement: step 2, image 1 of 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx RAM Replacement: step 3, image 1 of 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx RAM Replacement: step 4, image 1 of 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx RAM Replacement, RAM: step 5, image 1 of 1
    • The RAM sticks are located in the right upper corner of the laptop of the laptop.
  6. HP Envy m6-k022dx RAM Replacement: step 6, image 1 of 1
    • There are two clips holding each RAM stick in place; one on each side of each stick.
    • Gently pull each clips outwards, away from the RAM sticks. They will easily unclip from the RAM.
  7. HP Envy m6-k022dx RAM Replacement: step 7, image 1 of 1
    • Grab the top of the RAM stick and pull directly up, towards the outer edge of the laptop.
    • The RAM sticks will slide out from their slots relatively easily. They are now ready to be replaced.
3 other people completed this guide.
Anthony Stubbs
182 Reputation
1 Guide authored
USF Tampa, Team S13-G6, Cagle Spring 2017 Member of USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,138
