HP Envy m6-k022dx Speaker Replacement
  1. HP Envy m6-k022dx Speaker Replacement, Lower Case: step 1, image 1 of 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx Speaker Replacement: step 2, image 1 of 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx Speaker Replacement: step 3, image 1 of 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx Speaker Replacement: step 4, image 1 of 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx Speaker Replacement, Speaker: step 5, image 1 of 1
    • Remove the two screws holding the speaker in place.
    • There are two red rubber grommets which stay situated in the screw guide holes; be sure not to lose these.
  6. HP Envy m6-k022dx Speaker Replacement: step 6, image 1 of 1
    • Once the screws have been removed, gently lift the speaker straight up, but just enough to dislodge it.
    • There is a cable connecting the speakers to the sound board. Be sure to not tug on this connection when lifting the speaker.
  7. HP Envy m6-k022dx Speaker Replacement: step 7, image 1 of 1
    • Once the speaker is dislodged, gently pull the connecting cable from the sound card.
    • The speaker is now fully removed and ready to be replaced.
Kareem Rigaud
403 Reputation
3 Guides authored
USF Tampa, Team S13-G6, Cagle Spring 2017 Member of USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 20
All Time: 717
