HP Envy m6-p114dx Battery Replacement
  1. HP Envy m6-p114dx Battery Replacement, Back Panel: step 1, image 1 of 3 HP Envy m6-p114dx Battery Replacement, Back Panel: step 1, image 2 of 3 HP Envy m6-p114dx Battery Replacement, Back Panel: step 1, image 3 of 3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Battery Replacement: step 2, image 1 of 1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Battery Replacement: step 3, image 1 of 1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Battery Replacement, Battery: step 4, image 1 of 2 HP Envy m6-p114dx Battery Replacement, Battery: step 4, image 2 of 2
    • Remove the cable connecting the hard drive to the motherboard by carefully lifting the black tab, then pulling out the disconnected ribbon cable.
  5. HP Envy m6-p114dx Battery Replacement: step 5, image 1 of 2 HP Envy m6-p114dx Battery Replacement: step 5, image 2 of 2
    • Remove the cable connecting the battery to the motherboard by gripping the fabric and pulling downward.
    • The cable is connected next to the RAM cards.
  6. HP Envy m6-p114dx Battery Replacement: step 6, image 1 of 2 HP Envy m6-p114dx Battery Replacement: step 6, image 2 of 2
    • Remove the six screws that hold the battery down with a Phillips #0 screwdriver.
    • Once the screws are removed you should be able to easily lift up on the battery to remove it. (You may need to detach the ribbon cable glued to the battery )
Taylor Cheney
527 Reputation
4 Guides authored
Gateway, Team S1-G1, Saknee Fall 2019 Member of Gateway, Team S1-G1, Saknee Fall 2019
GCC-SAKNEE-F19S1G1
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,087
