HP Envy m6-p114dx Ram Replacement
  1. HP Envy m6-p114dx Ram Replacement, Back Panel: step 1, image 1 of 3 HP Envy m6-p114dx Ram Replacement, Back Panel: step 1, image 2 of 3 HP Envy m6-p114dx Ram Replacement, Back Panel: step 1, image 3 of 3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Ram Replacement: step 2, image 1 of 1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Ram Replacement: step 3, image 1 of 1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Ram Replacement, Ram: step 4, image 1 of 3 HP Envy m6-p114dx Ram Replacement, Ram: step 4, image 2 of 3 HP Envy m6-p114dx Ram Replacement, Ram: step 4, image 3 of 3
    • There will be two metal tabs on the side of the stick, carefully push down the stick then push the clips to the side to detach it from the slot
    • Remove the RAM by pulling it directly out of the port.
  5. HP Envy m6-p114dx Ram Replacement: step 5, image 1 of 1
    • Insert RAM stick all the way into the slot, lining up the groove in the stick.
    • Press firmly down until the tabs click into place
Taylor Cheney
527 Reputation
4 Guides authored
Gateway, Team S1-G1, Saknee Fall 2019 Member of Gateway, Team S1-G1, Saknee Fall 2019
GCC-SAKNEE-F19S1G1
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 212
