HP Envy m6-p114dx Speaker Replacement
  1. HP Envy m6-p114dx Speaker Replacement, Back Panel: step 1, image 1 of 3 HP Envy m6-p114dx Speaker Replacement, Back Panel: step 1, image 2 of 3 HP Envy m6-p114dx Speaker Replacement, Back Panel: step 1, image 3 of 3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Speaker Replacement: step 2, image 1 of 1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Speaker Replacement: step 3, image 1 of 1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Speaker Replacement, Speaker: step 4, image 1 of 3 HP Envy m6-p114dx Speaker Replacement, Speaker: step 4, image 2 of 3 HP Envy m6-p114dx Speaker Replacement, Speaker: step 4, image 3 of 3
    • Unscrew the two screws that have a pink spacer below them with a Phillips #0 screwdriver.
    • Lift directly up to remove the main speaker.
    • Gently pull the wire out of the plastic track that it's set in.
  5. HP Envy m6-p114dx Speaker Replacement: step 5, image 1 of 1
    • Follow the cable around the inside of the case and remove the cable to the main board
    • Once this is removed you can fully remove the speaker!
Shad Padilla
112 Reputation
1 Guide authored
Gateway, Team S1-G1, Saknee Fall 2019 Member of Gateway, Team S1-G1, Saknee Fall 2019
GCC-SAKNEE-F19S1G1
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 190
