HP Envy x360 15-bp143cl Daughterboard Replacement
  1. HP Envy x360 15-bp143cl Daughterboard Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Daughterboard Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Daughterboard Replacement: step 3, image 1 of 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Daughterboard Replacement: step 4, image 1 of 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Daughterboard Replacement: step 5, image 1 of 2 HP Envy x360 15-bp143cl Daughterboard Replacement: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Daughterboard Replacement: step 6, image 1 of 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Daughterboard Replacement, Motherboard: step 7, image 1 of 1
    • Peel off the tape securing the heatsink.
  8. HP Envy x360 15-bp143cl Daughterboard Replacement: step 8, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the seven 4 mm screws securing the fan.
    • Detach the fan cable from the mother board.
  9. HP Envy x360 15-bp143cl Daughterboard Replacement: step 9, image 1 of 1
    • Lift the fan up and off the motherboard.
  10. HP Envy x360 15-bp143cl Daughterboard Replacement: step 10, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the ten 4 mm screws securing the motherboard.
    • Pull the four cables directly out of their ports.
    • Flip up the lock-bar on the two ZIF connectors, then gently pull the two ribbon cables directly out of their ports.
  11. HP Envy x360 15-bp143cl Daughterboard Replacement: step 11, image 1 of 1
    • Gently lift the motherboard up and out of the chassis.
  12. HP Envy x360 15-bp143cl Daughterboard Replacement, Daughterboard: step 12, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw securing the daughterboard.
    • Disconnect the ribbon cable.
  13. HP Envy x360 15-bp143cl Daughterboard Replacement: step 13, image 1 of 1
    • Gently lift the daughterboard up and out of the laptop.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 219
