HP Envy x360 15-bp143cl Touchpad Replacement
Spencer Berkins
Spencer Berkins and 4 other contributors
Last updated on December 30, 2019
15 - 20 minutes
Moderate
Introduction
Go to step 1
Use this guide to replace a broken touch pad in an HP Envy x360 15-bp143cl. The laptop is also identified by its model number, 3TS71UAR#ABA.
A broken touch pad will be unresponsive and will not allow a user to move the cursor without an external mouse. If this is the case, the touch pad will need to be replaced.
Before using this replacement guide, review the HP Envy x360 15-bp143cl Touch pad Troubleshooting page to make sure the touch pad is not disabled. You can use this page to check if any other factor is causing the touch pad not to respond.
Turn the laptop off and disconnect it from any power supply before starting the replacement process.
Wear the Anti-Static Wrist Strap before working near the motherboard to prevent any damage.
Tools
Show more…
  1. HP Envy x360 15-bp143cl Touchpad Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Touchpad Replacement: step 2, image 1 of 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Touchpad Replacement: step 3, image 1 of 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Touchpad Replacement: step 4, image 1 of 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Touchpad Replacement: step 5, image 1 of 2 HP Envy x360 15-bp143cl Touchpad Replacement: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Touchpad Replacement: step 6, image 1 of 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: step 7, image 1 of 2 HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: step 7, image 2 of 2
    • Use a spudger to peel the silver tape near the top right side of the touch pad.
  8. HP Envy x360 15-bp143cl Touchpad Replacement: step 8, image 1 of 2 HP Envy x360 15-bp143cl Touchpad Replacement: step 8, image 2 of 2
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 4mm screws securing the bottom metal bar.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 1mm screws securing the top of the touch pad.
  9. HP Envy x360 15-bp143cl Touchpad Replacement: step 9, image 1 of 1
    • Remove the metal cover by lifting it away from the laptop.
  10. HP Envy x360 15-bp143cl Touchpad Replacement: step 10, image 1 of 2 HP Envy x360 15-bp143cl Touchpad Replacement: step 10, image 2 of 2
    • Lift the bottom side of the touch pad.
    • Lift the black tab that secures the touch pad connecting cable to the laptop.
    • Pull the cable from the touch pad connecting port.
  11. HP Envy x360 15-bp143cl Touchpad Replacement: step 11, image 1 of 2 HP Envy x360 15-bp143cl Touchpad Replacement: step 11, image 2 of 2
    • Lift the touch pad to remove it.
Spencer Berkins
577 Reputation
4 Guides authored
Cal Poly, Team S12-G3, Regan Fall 2019 Member of Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
3 Members
6 Guides authored
One Comment
Thanks now have to find one on E-bay….or?
Michael - Reply
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 38
All Time: 1,765
