HP Envy x360 15-u473cl Hard Drive Replacement
  1. HP Envy x360 15-u473cl Hard Drive Replacement, Battery: step 1, image 1 of 2 HP Envy x360 15-u473cl Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Hard Drive Replacement: step 2, image 1 of 1
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Hard Drive Replacement: step 3, image 1 of 2 HP Envy x360 15-u473cl Hard Drive Replacement: step 3, image 2 of 2
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Hard Drive Replacement: step 4, image 1 of 1
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Hard Drive Replacement: step 5, image 1 of 1
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Hard Drive Replacement: step 6, image 1 of 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Hard Drive Replacement: step 7, image 1 of 1
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl Hard Drive Replacement, Hard Drive: step 8, image 1 of 1
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  9. HP Envy x360 15-u473cl Hard Drive Replacement: step 9, image 1 of 2 HP Envy x360 15-u473cl Hard Drive Replacement: step 9, image 2 of 2
    • Remove the back cover by using the black spudger to lift up on the edges of the cover.
    • Using a suction cup to assist in lifting the back cover.
    • Use the Philips #0 screwdriver to remove six M2.x3.2 screws from the battery.
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
    • Lift and pull the front of the battery up and out (away from the connector) to remover.
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan.
    • Be careful as the fan might be sharp in some places when removing it.
  10. Tool used on this step:
    Buy
    • Remove the connector clip with the tweezers.
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
    • Remove the cooling fan.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,847
