HP Envy x360 15m-bp111dx Back Panel Replacement
  1. HP Envy x360 15m-bp111dx Back Panel Replacement, Back Panel: step 1, image 1 of 2 HP Envy x360 15m-bp111dx Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Back Panel Replacement: step 2, image 1 of 3 HP Envy x360 15m-bp111dx Back Panel Replacement: step 2, image 2 of 3 HP Envy x360 15m-bp111dx Back Panel Replacement: step 2, image 3 of 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
2 other people completed this guide.
Jack Bjelland
183 Reputation
1 Guide authored
Clemson, Team 2-2, Hunter Spring 2022 Member of Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 713
