HP Envy x360 15m-bq021dx Battery Replacement
  1. HP Envy x360 15m-bq021dx Battery Replacement, Battery: step 1, image 1 of 2 HP Envy x360 15m-bq021dx Battery Replacement, Battery: step 1, image 2 of 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Battery Replacement: step 2, image 1 of 3 HP Envy x360 15m-bq021dx Battery Replacement: step 2, image 2 of 3 HP Envy x360 15m-bq021dx Battery Replacement: step 2, image 3 of 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Battery Replacement: step 3, image 1 of 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Battery Replacement: step 4, image 1 of 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Battery Replacement: step 5, image 1 of 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
One Comment
Mr. Reihart thank you for this information, could you also say what battery to purchase as a replacement for the 15m -bq.
J r - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 75
All Time: 2,269
