HP Envy x360 15m-bq021dx RAM Replacement
  1. HP Envy x360 15m-bq021dx RAM Replacement, Battery: step 1, image 1 of 2 HP Envy x360 15m-bq021dx RAM Replacement, Battery: step 1, image 2 of 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx RAM Replacement: step 2, image 1 of 3 HP Envy x360 15m-bq021dx RAM Replacement: step 2, image 2 of 3 HP Envy x360 15m-bq021dx RAM Replacement: step 2, image 3 of 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx RAM Replacement: step 3, image 1 of 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx RAM Replacement: step 4, image 1 of 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx RAM Replacement: step 5, image 1 of 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx RAM Replacement, RAM: step 6, image 1 of 1
    • Remove the tape near the RAM storage.
  7. HP Envy x360 15m-bq021dx RAM Replacement: step 7, image 1 of 2 HP Envy x360 15m-bq021dx RAM Replacement: step 7, image 2 of 2
    • Use a small blue opening tool to pry open the protective metal cover.
  8. HP Envy x360 15m-bq021dx RAM Replacement: step 8, image 1 of 1
    • Pull on the silver pins away from the RAM on both sides.
  9. HP Envy x360 15m-bq021dx RAM Replacement: step 9, image 1 of 2 HP Envy x360 15m-bq021dx RAM Replacement: step 9, image 2 of 2
    • Pull the RAM up and out to remove.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 1,693
