You're viewing a previously published version of this guide.  View latest version
Older Newer
HP Envy x360 15m-cn0011dx Battery Replacement
Skylar Moore
Skylar Moore and one other contributor
Last updated on December 27, 2022
7 minutes
Easy
Introduction
Go to step 1
This guide will demonstrate how to replace the battery in the HP Envy x360 15m-cn0011dx laptop.
The battery is the component in the computer to power on the device. If you don't have a battery then you can not turn your computer on.
A swollen battery has less power life compared to a new one. If your battery is swollen then this guide is for you. It will show how to replace a swollen battery.
Make sure your device is fully powered off before attempting this guide.
Tools
  1. HP Envy x360 15m-cn0011dx Battery Replacement, Back Cover: step 1, image 1 of 1
    • Flip the laptop over to the back side.
  2. HP Envy x360 15m-cn0011dx Battery Replacement: step 2, image 1 of 2 HP Envy x360 15m-cn0011dx Battery Replacement: step 2, image 2 of 2
    • Remove the six 5.6 mm screws from the back cover using a Phillips #00 screwdriver.
    • Remove the single 4.3 mm screw in the bottom middle section of the back cover using a T5 Torx screwdriver.
  3. HP Envy x360 15m-cn0011dx Battery Replacement: step 3, image 1 of 1
    • Lift the back cover off the laptop.
  4. HP Envy x360 15m-cn0011dx Battery Replacement, Battery: step 4, image 1 of 3 HP Envy x360 15m-cn0011dx Battery Replacement, Battery: step 4, image 2 of 3 HP Envy x360 15m-cn0011dx Battery Replacement, Battery: step 4, image 3 of 3
    • Remove the six 3.3 mm screws from the battery pack using a Phillips #00 screwdriver.
  5. HP Envy x360 15m-cn0011dx Battery Replacement: step 5, image 1 of 1
    • Lift the battery from the bottom of the laptop and and gently lift it up as you slowly unplug it from the connector on the top of the battery pack.
Skylar Moore
715 Reputation
5 Guides authored
Gateway, Team 1-4, Class Fall 2022 Member of Gateway, Team 1-4, Class Fall 2022
GCC-CLASS-F22S1G4
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 46
All Time: 1,442
