HP Envy x360 15m-cn0011dx RAM Replacement
  1. HP Envy x360 15m-cn0011dx RAM Replacement, Back Cover: step 1, image 1 of 1
    • Flip the laptop over to the back side.
  2. HP Envy x360 15m-cn0011dx RAM Replacement: step 2, image 1 of 2 HP Envy x360 15m-cn0011dx RAM Replacement: step 2, image 2 of 2
    • Remove the six 5.6 mm screws from the back cover using a Phillips #00 screwdriver.
    • Remove the single 4.3 mm screw in the bottom middle section of the back cover using a T5 Torx screwdriver.
  3. HP Envy x360 15m-cn0011dx RAM Replacement: step 3, image 1 of 1
    • Lift the back cover off the laptop.
  4. HP Envy x360 15m-cn0011dx RAM Replacement, RAM: step 4, image 1 of 1
    • Remove the metal plate that is covering the RAM.
  5. HP Envy x360 15m-cn0011dx RAM Replacement: step 5, image 1 of 1
    • Press the RAM placement tabs outward so the RAM stick pops upward.
  6. HP Envy x360 15m-cn0011dx RAM Replacement: step 6, image 1 of 1
    • Gently pull the RAM stick out of the RAM slot.
Skylar Moore
715 Reputation
5 Guides authored
Gateway, Team 1-4, Class Fall 2022 Member of Gateway, Team 1-4, Class Fall 2022
GCC-CLASS-F22S1G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 30
All Time: 452
