HP Envy x360 15m-cn0012dx Hard Drive Replacement
  1. HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 2, image 1 of 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 2, image 2 of 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 2, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 3, image 1 of 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 3, image 2 of 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 3, image 3 of 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 4, image 1 of 2 HP Envy x360 15m-cn0012dx Hard Drive Replacement: step 4, image 2 of 2
    • Use the Phillips #0 screwdriver to remove one screw from the bottom left corner of the laptop.
    • Use the iFixit opening tool to lift the latch and detach the connector to the motherboard.
    • Remove the hard drive.
    • When replacing the hard drive, you will likely have to transfer the SATA cable and hardware from your old drive to the new one before reinstalling.
Grace Daleki
487 Reputation
3 Guides authored
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Member of UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 24
Past 30 Days: 91
All Time: 6,174
