HP Envy x360 m6-aq003dx CPU Fan Replacement
  1. HP Envy x360 m6-aq003dx CPU Fan Replacement, Back Panel: step 1, image 1 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement, Back Panel: step 1, image 2 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement, Back Panel: step 1, image 3 of 3
    • Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
  2. HP Envy x360 m6-aq003dx CPU Fan Replacement: step 2, image 1 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement: step 2, image 2 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement: step 2, image 3 of 3
    • Use the Torx T5 screwdriver to remove the six small screws.
    • Use the Phillips #0 screwdriver to remove the screws under the rubber pads in step 1.
  3. HP Envy x360 m6-aq003dx CPU Fan Replacement: step 3, image 1 of 1
    • Go slowly around the edge with the opening tool. The noises you will hear are due to the small joints popping open. Continue this until you have made your way around the entire laptop.
  4. HP Envy x360 m6-aq003dx CPU Fan Replacement, CPU Fan: step 4, image 1 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement, CPU Fan: step 4, image 2 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement, CPU Fan: step 4, image 3 of 3
    • Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
    • Remove the cable from the connector.
  5. HP Envy x360 m6-aq003dx CPU Fan Replacement: step 5, image 1 of 2 HP Envy x360 m6-aq003dx CPU Fan Replacement: step 5, image 2 of 2
    • Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers.
    • You will hear clicking sounds when the black cable is removed.
  6. HP Envy x360 m6-aq003dx CPU Fan Replacement: step 6, image 1 of 2 HP Envy x360 m6-aq003dx CPU Fan Replacement: step 6, image 2 of 2
    • Disconnect the port with the red, yellow, and black wires by removing the wires with your fingers.
  7. HP Envy x360 m6-aq003dx CPU Fan Replacement: step 7, image 1 of 1
    • Remove the two 4.5mm Phillips #1 screws.
  8. HP Envy x360 m6-aq003dx CPU Fan Replacement: step 8, image 1 of 2 HP Envy x360 m6-aq003dx CPU Fan Replacement: step 8, image 2 of 2
    • Loosen the four black screws on the tail end of the fan with a Phillips head 1 screwdriver.
    • These screws do not come off.
  9. HP Envy x360 m6-aq003dx CPU Fan Replacement: step 9, image 1 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement: step 9, image 2 of 3 HP Envy x360 m6-aq003dx CPU Fan Replacement: step 9, image 3 of 3
    • Lift the CPU fan out with your hand.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 461
