HP Envy x360 m6-aq103dx Bottom Cover Replacement
  1. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: step 1, image 3 of 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Bottom Cover Replacement: step 2, image 1 of 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Bottom Cover Replacement: step 3, image 1 of 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Bottom Cover Replacement: step 4, image 1 of 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: step 4, image 2 of 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: step 4, image 3 of 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
8 other people completed this guide.
Sarah Samora
789 Reputation
3 Guides authored
Cal Poly, Team S4-G3, Livingston Fall 2017 Member of Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Members
9 Guides authored
4 Comments
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Joshua Bowman - Reply
It was really easy to open.
[deleted] - Reply
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
MrHarris73 - Reply
But where can i purchase the bottom cover
imran abdulhameed - Reply
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 59
All Time: 9,104
