HP Envy x360 m6-aq105dx Battery Replacement
  1. HP Envy x360 m6-aq105dx Battery Replacement, Back Cover: step 1, image 1 of 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Battery Replacement: step 2, image 1 of 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Battery Replacement, Battery: step 3, image 1 of 1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the six 4.6mm screws securing the battery using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Battery Replacement: step 4, image 1 of 1
    • Disconnect the power supply cable connected to the motherboard.
  5. HP Envy x360 m6-aq105dx Battery Replacement: step 5, image 1 of 2 HP Envy x360 m6-aq105dx Battery Replacement: step 5, image 2 of 2
    • Remove the battery from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 13
All Time: 1,352
