HP Envy x360 m6-w101dx Fan Replacement
  1. HP Envy x360 m6-w101dx Fan Replacement, Keyboard Panel: step 1, image 1 of 1
    • Place the laptop so that the bottom panel is facing upwards.
  2. HP Envy x360 m6-w101dx Fan Replacement: step 2, image 1 of 3 HP Envy x360 m6-w101dx Fan Replacement: step 2, image 2 of 3 HP Envy x360 m6-w101dx Fan Replacement: step 2, image 3 of 3
    • Remove the screw covers using an iFixit opening tool.
  3. HP Envy x360 m6-w101dx Fan Replacement: step 3, image 1 of 1
    • Remove twelve 8 mm Phillips #1 screws.
  4. HP Envy x360 m6-w101dx Fan Replacement: step 4, image 1 of 3 HP Envy x360 m6-w101dx Fan Replacement: step 4, image 2 of 3 HP Envy x360 m6-w101dx Fan Replacement: step 4, image 3 of 3
    • Pry open a gap in the edge of the keyboard with an iFixit opening tool.
  5. HP Envy x360 m6-w101dx Fan Replacement: step 5, image 1 of 1
    • Remove the keyboard from the laptop.
  6. HP Envy x360 m6-w101dx Fan Replacement, Fan: step 6, image 1 of 1
    • Remove the five 4.5mm Phillips #1 screws surrounding the fan.
  7. HP Envy x360 m6-w101dx Fan Replacement: step 7, image 1 of 1
    • Remove the three 4.5mm Phillips #1 screws from right side of the motherboard.
  8. HP Envy x360 m6-w101dx Fan Replacement: step 8, image 1 of 1
    • Detach the cable between the CPU and the motherboard.
  9. HP Envy x360 m6-w101dx Fan Replacement: step 9, image 1 of 1
    • Detach the cable between the battery and the motherboard.
  10. HP Envy x360 m6-w101dx Fan Replacement: step 10, image 1 of 1
    • Disconnect the cable between the SD card and the motherboard.
  11. HP Envy x360 m6-w101dx Fan Replacement: step 11, image 1 of 1
    • Disconnect the cable between the screen and the motherboard.
  12. HP Envy x360 m6-w101dx Fan Replacement: step 12, image 1 of 1
    • Detach the connection between the fan and the motherboard.
  13. HP Envy x360 m6-w101dx Fan Replacement: step 13, image 1 of 1
    • Disconnect the cable from the speaker to the motherboard.
  14. HP Envy x360 m6-w101dx Fan Replacement: step 14, image 1 of 1
    • Disconnect the cable between the CPU and the power interface.
  15. HP Envy x360 m6-w101dx Fan Replacement: step 15, image 1 of 1
    • Turn the connected motherboard and fan upside down and remove the four 4.5mm Phillips #1 screws from the middle of the back of the motherboard.
  16. HP Envy x360 m6-w101dx Fan Replacement: step 16, image 1 of 1
    • Disconnect the cable connecting the fan to the motherboard.
  17. HP Envy x360 m6-w101dx Fan Replacement: step 17, image 1 of 1
    • Remove the fan from the laptop.
Wenxuan Zhang
255 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 676
