HP Flyer Red Screen Replacement
  1. HP Flyer Red Screen Replacement, Battery: step 1, image 1 of 2 HP Flyer Red Screen Replacement, Battery: step 1, image 2 of 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Screen Replacement: step 2, image 1 of 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Screen Replacement: step 3, image 1 of 2 HP Flyer Red Screen Replacement: step 3, image 2 of 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Screen Replacement: step 4, image 1 of 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
  5. HP Flyer Red Screen Replacement, Screen: step 5, image 1 of 1
    • Flip over and open up the laptop with screen facing you.
  6. HP Flyer Red Screen Replacement: step 6, image 1 of 3 HP Flyer Red Screen Replacement: step 6, image 2 of 3 HP Flyer Red Screen Replacement: step 6, image 3 of 3
    • Slide plastic opening tool in crack at the top corner of the outer frame of the screen (in the gap between the red and black sections of plastic) and pry apart as shown.
    • Pry apart all edges the same as the top. Use the spudger for the bottom section as it is glued to tape, make sure to pry this apart carefully and the tape should be separated from the black plastic part as shown.
    • The glue is difficult to separate.
  7. HP Flyer Red Screen Replacement: step 7, image 1 of 2 HP Flyer Red Screen Replacement: step 7, image 2 of 2
    • Separate the black plastic frame from the body of the computer by sliding it up and towards you while rotating the top section away from you.
  8. HP Flyer Red Screen Replacement: step 8, image 1 of 3 HP Flyer Red Screen Replacement: step 8, image 2 of 3 HP Flyer Red Screen Replacement: step 8, image 3 of 3
    • Unscrew the 4x 4mm Phillips #1 screws from the four corners of the screen they are the ones that are attached to the metal tabs coming from the screen itself.
  9. HP Flyer Red Screen Replacement: step 9, image 1 of 2 HP Flyer Red Screen Replacement: step 9, image 2 of 2
    • Pull the screen away from the plastic backing there will be a plug on the bottom section of the screen near the keyboard.
    • Take small metal spudger and gently scrape up the sticker holding the screen in place.
  10. HP Flyer Red Screen Replacement: step 10, image 1 of 2 HP Flyer Red Screen Replacement: step 10, image 2 of 2
    • Use a plastic opening tool to lift up the black tab on the ZIF connector.
    • Slowly pull the ribbon cable out of the connector.
3 other people completed this guide.
Anthony Ciotti
777 Reputation
5 Guides authored
1 Guide Comment
What screen would fit that laptop
supermiguel719 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 3,712
