HP Folio 13t-1000 Keyboard Replacement
  1. HP Folio 13t-1000 Keyboard Replacement, Keyboard: step 1, image 1 of 2 HP Folio 13t-1000 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Keyboard Replacement: step 2, image 1 of 3 HP Folio 13t-1000 Keyboard Replacement: step 2, image 2 of 3 HP Folio 13t-1000 Keyboard Replacement: step 2, image 3 of 3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Keyboard Replacement: step 3, image 1 of 1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Keyboard Replacement: step 4, image 1 of 2 HP Folio 13t-1000 Keyboard Replacement: step 4, image 2 of 2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Keyboard Replacement: step 5, image 1 of 3 HP Folio 13t-1000 Keyboard Replacement: step 5, image 2 of 3 HP Folio 13t-1000 Keyboard Replacement: step 5, image 3 of 3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Keyboard Replacement: step 6, image 1 of 3 HP Folio 13t-1000 Keyboard Replacement: step 6, image 2 of 3 HP Folio 13t-1000 Keyboard Replacement: step 6, image 3 of 3
    • Remove the keyboard from the laptop.
2 other people completed this guide.
Cody Badchkam
64 Reputation
4 Guides authored
USF Tampa, Team 1-2, Cagle Fall 2016 Member of USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
4 Members
7 Guides authored
2 Comments
Awsome Thanks! had my keyboard flooded with some cola :( .. Fixed it !
Matthijs Aveskamp - Reply
Turn your Folio 13 upside down.
Looking at the screws on the back, work out which ones go into the keyboard to retain it (it’s only 3!).
You only need to take those screws out.
Use something thin and flat to go around the keyboard, separating it from the case front.
It will lift out easily.
There is no need to remove all 16 screws or take the case front off.
Neon Blade - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 864
