HP G60-443CL RAM Replacement
  1. HP G60-443CL RAM Replacement, RAM: step 1, image 1 of 1
    • Unscrew and remove the two 5mm Philips #0 screws that keep the cover on.
  2. HP G60-443CL RAM Replacement: step 2, image 1 of 2 HP G60-443CL RAM Replacement: step 2, image 2 of 2
    • Remove cover.
  3. HP G60-443CL RAM Replacement: step 3, image 1 of 2 HP G60-443CL RAM Replacement: step 3, image 2 of 2
    • Press on the two levers on either side of the first RAM.
    • The RAM will pop up if the levers have been pushed properly.
  4. HP G60-443CL RAM Replacement: step 4, image 1 of 1
    • Gently remove the first RAM.
  5. HP G60-443CL RAM Replacement: step 5, image 1 of 2 HP G60-443CL RAM Replacement: step 5, image 2 of 2
    • Repeat steps 1-4 for the second RAM.
    • After gently taking the second RAM out, the RAMs have successfully been removed.
Samantha
201 Reputation
2 Guides authored
Baylor, Team S8-G7, Johnson Fall 2017 Member of Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 343
