HP G62 347NR Motherboard Replacement
  1. HP G62 347NR Motherboard Replacement, Keyboard: step 1, image 1 of 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Motherboard Replacement: step 2, image 1 of 1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Motherboard Replacement: step 3, image 1 of 2 HP G62 347NR Motherboard Replacement: step 3, image 2 of 2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Motherboard Replacement: step 4, image 1 of 2 HP G62 347NR Motherboard Replacement: step 4, image 2 of 2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Motherboard Replacement: step 5, image 1 of 2 HP G62 347NR Motherboard Replacement: step 5, image 2 of 2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Motherboard Replacement: step 6, image 1 of 2 HP G62 347NR Motherboard Replacement: step 6, image 2 of 2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Motherboard Replacement: step 7, image 1 of 2 HP G62 347NR Motherboard Replacement: step 7, image 2 of 2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
  8. HP G62 347NR Motherboard Replacement, Remove palmrest: step 8, image 1 of 3 HP G62 347NR Motherboard Replacement, Remove palmrest: step 8, image 2 of 3 HP G62 347NR Motherboard Replacement, Remove palmrest: step 8, image 3 of 3
    • Remove the single M2.5x5 blue-painted screw securing the palmrest, from under where the keyboard was.
    • Remove the connectors from the motherboard.
    • Close the laptop's screen, and flip the laptop over.
    • Remove the twelve M2.5x6.5 red-painted screws.
    • Remove the four M2.5x3 screws securing the palmrest to the base.
    • Remove the screw for the wireless card, as well as the wireless antennas, and take the wireless card out.
  9. HP G62 347NR Motherboard Replacement, Remove motherboard: step 9, image 1 of 1
    • Remove the two blue-painted M2.5x4 screws securing the motherboard to the base.
    • Remove all connectors from the motherboard.
    • Transfer your heatsink, processor, and memory to the replacement board. You're done!
Joseph Sctbunio
7,416 Reputation
42 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,519
