HP G62-144DX Fan/heat Sink module Replacement
  1. HP G62-144DX Fan/heat Sink module Replacement, Battery: step 1, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement, Battery: step 1, image 2 of 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Fan/heat Sink module Replacement, Hard Drive: step 2, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement, Hard Drive: step 2, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement, Hard Drive: step 2, image 3 of 3
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Fan/heat Sink module Replacement: step 3, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 3, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 3, image 3 of 3
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
  4. HP G62-144DX Fan/heat Sink module Replacement, RAM: step 4, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement, RAM: step 4, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement, RAM: step 4, image 3 of 3
    • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but will come loose from the body of the laptop.
    • Use a plastic opening tool to gently pry the panel free from the laptop.
  5. HP G62-144DX Fan/heat Sink module Replacement: step 5, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 5, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 5, image 3 of 3
    • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
    • After the RAM module pops up, gently pull in out from the computer.
    • Repeat for the second RAM module.
  6. HP G62-144DX Fan/heat Sink module Replacement, Keyboard: step 6, image 1 of 1
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  7. HP G62-144DX Fan/heat Sink module Replacement: step 7, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 7, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 7, image 3 of 3
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  8. HP G62-144DX Fan/heat Sink module Replacement: step 8, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement: step 8, image 2 of 2
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  9. HP G62-144DX Fan/heat Sink module Replacement: step 9, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement: step 9, image 2 of 2
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  10. HP G62-144DX Fan/heat Sink module Replacement: step 10, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement: step 10, image 2 of 2
    • Pull up the latch that connects the keyboard connector the the motherboard.
  11. HP G62-144DX Fan/heat Sink module Replacement, Motherboard: step 11, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement, Motherboard: step 11, image 2 of 2
    • Remove four Phillips PM2.5x3 screws in the battery bay, and remove ten Phillips PM2.5x6.5 screws on the base enclosure with a Phillips #1 screwdriver.
  12. HP G62-144DX Fan/heat Sink module Replacement: step 12, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement: step 12, image 2 of 2
    • Remove the Phillips PM2.0×3.0 screw that secures the WLAN module to the computer with a Phillips #0 screwdriver.
  13. HP G62-144DX Fan/heat Sink module Replacement: step 13, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 13, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 13, image 3 of 3
    • Disconnect the two wires that attach the card to the motherboard by pulling them up individually.
    • Grab the card gently and pull it out after it pops up.
  14. HP G62-144DX Fan/heat Sink module Replacement: step 14, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 14, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 14, image 3 of 3
    • Flip the laptop over so that the top is facing upwards.
    • Remove the Phillips PM2.5×6.0 screw that secures the top cover to the computer with a Phillips #1 screwdriver.
    • Disconnect the 4 connectors to the motherboard.
  15. HP G62-144DX Fan/heat Sink module Replacement: step 15, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement: step 15, image 2 of 2
    • Take off the cover by prying open the cover with a plastic opening tool.
    • Lift the edge near the display first until it pops out, and then remove the cover by pulling it out.
    • The cover should come out with ease. If you having trouble pulling the cover out you should double check to see if any screws were left unscrew.
  16. HP G62-144DX Fan/heat Sink module Replacement: step 16, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 16, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 16, image 3 of 3
    • Remove the two motherboard screws and the fan screw that holds it on the the rest of the computer with a Phillips #1 screwdriver.
  17. HP G62-144DX Fan/heat Sink module Replacement: step 17, image 1 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 17, image 2 of 3 HP G62-144DX Fan/heat Sink module Replacement: step 17, image 3 of 3
    • Remove the six connectors from the motherboard.
    • The power connector is located underneth the USB connector.
  18. HP G62-144DX Fan/heat Sink module Replacement: step 18, image 1 of 1
    • Lift up the right side of the motherboard and pull it out to the right carefully.
  19. HP G62-144DX Fan/heat Sink module Replacement, Fan/heat Sink module: step 19, image 1 of 2 HP G62-144DX Fan/heat Sink module Replacement, Fan/heat Sink module: step 19, image 2 of 2
    • Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn on the computer, and then shut it down through the operating system.
    • Disconnect all external devices connected to the computer.
    • Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Disconnect the fan cable from the system board.
    • Loosen the four Phillips PM2.5×7.0 captive screws that secure the fan/heat sink assembly to the system board with a Phillips 0 screwdriver.
2 other people completed this guide.
Tom Pawlik
318 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,173
