HP G62-144DX Hard Drive Replacement
  1. HP G62-144DX Hard Drive Replacement, Battery: step 1, image 1 of 2 HP G62-144DX Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Hard Drive Replacement, Hard Drive: step 2, image 1 of 3 HP G62-144DX Hard Drive Replacement, Hard Drive: step 2, image 2 of 3 HP G62-144DX Hard Drive Replacement, Hard Drive: step 2, image 3 of 3
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Hard Drive Replacement: step 3, image 1 of 3 HP G62-144DX Hard Drive Replacement: step 3, image 2 of 3 HP G62-144DX Hard Drive Replacement: step 3, image 3 of 3
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
Cameron Moran
623 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 340
