HP G62-144DX Keyboard Replacement
  1. HP G62-144DX Keyboard Replacement, Battery: step 1, image 1 of 2 HP G62-144DX Keyboard Replacement, Battery: step 1, image 2 of 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  3. HP G62-144DX Keyboard Replacement: step 3, image 1 of 3 HP G62-144DX Keyboard Replacement: step 3, image 2 of 3 HP G62-144DX Keyboard Replacement: step 3, image 3 of 3
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  4. HP G62-144DX Keyboard Replacement: step 4, image 1 of 2 HP G62-144DX Keyboard Replacement: step 4, image 2 of 2
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  5. HP G62-144DX Keyboard Replacement: step 5, image 1 of 2 HP G62-144DX Keyboard Replacement: step 5, image 2 of 2
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  6. HP G62-144DX Keyboard Replacement: step 6, image 1 of 2 HP G62-144DX Keyboard Replacement: step 6, image 2 of 2
    • Pull up the latch that connects the keyboard connector the the motherboard.
2 other people completed this guide.
Cameron Moran
623 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 806
