HP G62-223CL Hard Drive Replacement
  1. HP G62-223CL Hard Drive Replacement, Battery Removal: step 1, image 1 of 2 HP G62-223CL Hard Drive Replacement, Battery Removal: step 1, image 2 of 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Hard Drive Replacement: step 2, image 1 of 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 HP G62-223CL Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Locate the two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Hard Drive Replacement: step 4, image 1 of 1
    • Locate the three 6 mm Phillips head screws for the hard drive.
    • Use a Phillips #0 screwdriver to remove the screws.
  5. HP G62-223CL Hard Drive Replacement: step 5, image 1 of 1
    • Remove the hard drive from the compartment.
    • Pull the connector cable from the end of the hard drive.
  6. HP G62-223CL Hard Drive Replacement: step 6, image 1 of 1
    • Locate the two 6 mm Phillips head screws on each side of the hard drive.
    • Remove the cover from the hard drive.
2 other people completed this guide.
Garret Layton
669 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Winter 2015 Member of USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 2,649
