HP G62-223CL Wireless Card Replacement
  1. HP G62-223CL Wireless Card Replacement, Battery Removal: step 1, image 1 of 2 HP G62-223CL Wireless Card Replacement, Battery Removal: step 1, image 2 of 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Wireless Card Replacement: step 2, image 1 of 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Wireless Card Replacement, Wireless Card: step 3, image 1 of 2 HP G62-223CL Wireless Card Replacement, Wireless Card: step 3, image 2 of 2
    • Locate three Phillips head retaining screws which secure the compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Wireless Card Replacement: step 4, image 1 of 3 HP G62-223CL Wireless Card Replacement: step 4, image 2 of 3 HP G62-223CL Wireless Card Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to disconnect the gray cable and the black cable from the wireless card.
  5. HP G62-223CL Wireless Card Replacement: step 5, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
  6. HP G62-223CL Wireless Card Replacement: step 6, image 1 of 1
    • Carefully lift and pull wireless card. It is removed!
Garret Layton
669 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Winter 2015 Member of USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,114
