HP G62-234DX CD Reader Replacement
  1. HP G62-234DX CD Reader Replacement, Battery: step 1, image 1 of 1
    • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
    • Unlock the battery by sliding the button just below it, to the left.
  2. HP G62-234DX CD Reader Replacement: step 2, image 1 of 1
    • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
    • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
  3. HP G62-234DX CD Reader Replacement, Hard Drive: step 3, image 1 of 3 HP G62-234DX CD Reader Replacement, Hard Drive: step 3, image 2 of 3 HP G62-234DX CD Reader Replacement, Hard Drive: step 3, image 3 of 3
    • It Is recommended to remove the RAM panel for easier access when removing the hard drive panel.
    • Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
    • Use a spudger to remove hard drive panel and carefully lift it up and out.
  4. HP G62-234DX CD Reader Replacement: step 4, image 1 of 1
    • Pull the hard drive from the SATA connector to remove the hard drive from the laptop.
  5. HP G62-234DX CD Reader Replacement, CD Reader: step 5, image 1 of 2 HP G62-234DX CD Reader Replacement, CD Reader: step 5, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the screw that holds the CD reader or optical driver in place.
    • Since there is no cover for this device this will be a improvised removal of the CD reader.
  6. HP G62-234DX CD Reader Replacement: step 6, image 1 of 2 HP G62-234DX CD Reader Replacement: step 6, image 2 of 2
    • To remove the CD reader gently push the the back of the CD reader from the hard drive slot and pull it out on the other side.
Cameron Popillo
337 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 69
