HP G62-234DX Keyboard Replacement
  1. HP G62-234DX Keyboard Replacement, Wi-Fi Card: step 1, image 1 of 3 HP G62-234DX Keyboard Replacement, Wi-Fi Card: step 1, image 2 of 3 HP G62-234DX Keyboard Replacement, Wi-Fi Card: step 1, image 3 of 3
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Keyboard Replacement: step 2, image 1 of 3 HP G62-234DX Keyboard Replacement: step 2, image 2 of 3 HP G62-234DX Keyboard Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
    • The screws that are attached to the panel do not need to be removed completely.
    • Remove the back panel to access the Wi-Fi card.
  3. HP G62-234DX Keyboard Replacement: step 3, image 1 of 3 HP G62-234DX Keyboard Replacement: step 3, image 2 of 3 HP G62-234DX Keyboard Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
  4. HP G62-234DX Keyboard Replacement: step 4, image 1 of 2 HP G62-234DX Keyboard Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
    • When the screw is removed the card will pop up at a 45-degree angle.
  5. HP G62-234DX Keyboard Replacement: step 5, image 1 of 3 HP G62-234DX Keyboard Replacement: step 5, image 2 of 3 HP G62-234DX Keyboard Replacement: step 5, image 3 of 3
    • Remove the Wi-Fi card by sliding it out from the socket.
  6. HP G62-234DX Keyboard Replacement, Keyboard: step 6, image 1 of 3 HP G62-234DX Keyboard Replacement, Keyboard: step 6, image 2 of 3 HP G62-234DX Keyboard Replacement, Keyboard: step 6, image 3 of 3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM chip.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Slide the RAM card out of the slot to remove it.
  7. HP G62-234DX Keyboard Replacement: step 7, image 1 of 2 HP G62-234DX Keyboard Replacement: step 7, image 2 of 2
    • Use a Phillips #0 screwdriver to remove three 6.5 mm screws.
    • Use a Phillips #0 screwdriver to remove three 5.0 mm screws.
  8. HP G62-234DX Keyboard Replacement: step 8, image 1 of 2 HP G62-234DX Keyboard Replacement: step 8, image 2 of 2
    • Rotate the laptop back to its standard orientation and flip open the screen.
    • Use the iFixit opening tool to separate the keyboard from the tabs. Start from one point on the edge and work your way around until all of the tabs are released.
  9. HP G62-234DX Keyboard Replacement: step 9, image 1 of 3 HP G62-234DX Keyboard Replacement: step 9, image 2 of 3 HP G62-234DX Keyboard Replacement: step 9, image 3 of 3
    • Flip the keyboard towards yourself.
    • Do not try to pull it out, as it is still connected to the ribbon cable.
  10. HP G62-234DX Keyboard Replacement: step 10, image 1 of 2 HP G62-234DX Keyboard Replacement: step 10, image 2 of 2
    • Flip up the locking flap using either your fingernail, or a spudger.
    • Remove the ribbon from the ZIF connector.
  11. HP G62-234DX Keyboard Replacement: step 11, image 1 of 1
    • Remove the keyboard.
To reassemble your device, follow these instructions in reverse order with the replacement keyboard. Make sure to be careful when reconnecting small or delicate pieces, and don't rush!
2 other people completed this guide.
Kate Ferland
836 Reputation
6 Guides authored
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 113
