HP G62-234DX Trackpad Replacement
  1. HP G62-234DX Trackpad Replacement, Wi-Fi Card: step 1, image 1 of 3 HP G62-234DX Trackpad Replacement, Wi-Fi Card: step 1, image 2 of 3 HP G62-234DX Trackpad Replacement, Wi-Fi Card: step 1, image 3 of 3
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Trackpad Replacement: step 2, image 1 of 3 HP G62-234DX Trackpad Replacement: step 2, image 2 of 3 HP G62-234DX Trackpad Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
    • The screws that are attached to the panel do not need to be removed completely.
    • Remove the back panel to access the Wi-Fi card.
  3. HP G62-234DX Trackpad Replacement: step 3, image 1 of 3 HP G62-234DX Trackpad Replacement: step 3, image 2 of 3 HP G62-234DX Trackpad Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
  4. HP G62-234DX Trackpad Replacement: step 4, image 1 of 2 HP G62-234DX Trackpad Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
    • When the screw is removed the card will pop up at a 45-degree angle.
  5. HP G62-234DX Trackpad Replacement: step 5, image 1 of 3 HP G62-234DX Trackpad Replacement: step 5, image 2 of 3 HP G62-234DX Trackpad Replacement: step 5, image 3 of 3
    • Remove the Wi-Fi card by sliding it out from the socket.
  6. HP G62-234DX Trackpad Replacement, Keyboard: step 6, image 1 of 3 HP G62-234DX Trackpad Replacement, Keyboard: step 6, image 2 of 3 HP G62-234DX Trackpad Replacement, Keyboard: step 6, image 3 of 3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM chip.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Slide the RAM card out of the slot to remove it.
  7. HP G62-234DX Trackpad Replacement: step 7, image 1 of 2 HP G62-234DX Trackpad Replacement: step 7, image 2 of 2
    • Use a Phillips #0 screwdriver to remove three 6.5 mm screws.
    • Use a Phillips #0 screwdriver to remove three 5.0 mm screws.
  8. HP G62-234DX Trackpad Replacement: step 8, image 1 of 2 HP G62-234DX Trackpad Replacement: step 8, image 2 of 2
    • Rotate the laptop back to its standard orientation and flip open the screen.
    • Use the iFixit opening tool to separate the keyboard from the tabs. Start from one point on the edge and work your way around until all of the tabs are released.
  9. HP G62-234DX Trackpad Replacement: step 9, image 1 of 3 HP G62-234DX Trackpad Replacement: step 9, image 2 of 3 HP G62-234DX Trackpad Replacement: step 9, image 3 of 3
    • Flip the keyboard towards yourself.
    • Do not try to pull it out, as it is still connected to the ribbon cable.
  10. HP G62-234DX Trackpad Replacement: step 10, image 1 of 2 HP G62-234DX Trackpad Replacement: step 10, image 2 of 2
    • Flip up the locking flap using either your fingernail, or a spudger.
    • Remove the ribbon from the ZIF connector.
  11. HP G62-234DX Trackpad Replacement: step 11, image 1 of 1
    • Remove the keyboard.
  12. HP G62-234DX Trackpad Replacement, Trackpad: step 12, image 1 of 3 HP G62-234DX Trackpad Replacement, Trackpad: step 12, image 2 of 3 HP G62-234DX Trackpad Replacement, Trackpad: step 12, image 3 of 3
    • Use a Phillips #0 screwdriver to remove two 6.0 mm screws.
    • Use the tip of a spudger or your fingernail to flip up the small locking flaps on the three connectors attached to the trackpad.
    • Pull the cables out gently.
  13. HP G62-234DX Trackpad Replacement: step 13, image 1 of 3 HP G62-234DX Trackpad Replacement: step 13, image 2 of 3 HP G62-234DX Trackpad Replacement: step 13, image 3 of 3
    • Use an opening tool and picks to pry the palm rest assembly from the device.
    • The trackpad is built into the palm rest assembly.
Kate Ferland
836 Reputation
6 Guides authored
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 78
