HP G71t-400 Cooling Fan Replacement
Introduction
Go to step 1When assessing whether to replace a laptop’s cooling fan, it is important to first assess the age and condition of the laptop. If the laptop is relatively new and in good condition, then it is probably not necessary to replace the cooling fan. Older laptops usually come equipped with high-quality fans that should last for a few years. However, if the laptop is a few years old and has been heavily used, then it may be beneficial to replace the fan. Over time, the fan can become clogged with dust and dirt, which reduces its efficiency and effectiveness. Replacing the fan can also be a good way to reduce the laptop’s noise level, as older fans tend to be louder than newer ones.
Lay the laptop down so the bottom is facing up.
Push the slide button, circled in photo 1, to release the battery.
Action in picture 2 shows the direction and release.
Tilt the battery back in the direction it popped up in and remove the battery.
This ensures there is no power in the system that could potentially short out any components.
