HP LaserJet 1160 or 1320 Main Motor Replacement
  1. HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: step 1, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: step 1, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: step 1, image 3 of 3
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. HP LaserJet 1160 or 1320 Main Motor Replacement, Right Side Cover: step 2, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Right Side Cover: step 2, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Right Side Cover: step 2, image 3 of 3
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. HP LaserJet 1160 or 1320 Main Motor Replacement, Back Cover: step 3, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Back Cover: step 3, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Back Cover: step 3, image 3 of 3
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  4. HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: step 4, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: step 4, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: step 4, image 3 of 3
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  5. HP LaserJet 1160 or 1320 Main Motor Replacement, Top Cover: step 5, image 1 of 1
    • Disconnect the control panel cable and remove the top cover.
  6. HP LaserJet 1160 or 1320 Main Motor Replacement, Fan: step 6, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fan: step 6, image 2 of 2
    • Disconnect the fan cable from the main board of the printer.
    • Remove the retaining clip holding the fan in.
    • Remove the 2 screws holding the fan in.
  7. HP LaserJet 1160 or 1320 Main Motor Replacement, Fan Cable: step 7, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fan Cable: step 7, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fan Cable: step 7, image 3 of 3
    • Remove the fan cable from the cable guide.
  8. HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer PCB: step 8, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer PCB: step 8, image 2 of 2
    • Disconnect one cable from the main board of the printer.
    • Disconnect the duplexer solenoid cable from the duplexer PCB.
    • Remove one screw on the duplexer PCB and remove the PCB from the printer.
  9. HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer Gears: step 9, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer Gears: step 9, image 2 of 2
    • Remove 3 screws holding the duplexer gears to the printer and remove the gears.
  10. HP LaserJet 1160 or 1320 Main Motor Replacement, Duplexer Solenoid: step 10, image 1 of 1
    • Remove one screw to remove the solenoid from the printer.
  11. HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: step 11, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: step 11, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Left Side Cover: step 11, image 3 of 3
  12. HP LaserJet 1160 or 1320 Main Motor Replacement, Formatter: step 12, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Formatter: step 12, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Formatter: step 12, image 3 of 3
    • Remove 2 screws on the I/O port cover.
    • Remove 6 screws on the formatter.
    • Disconnect 3 connectors from the formatter.
    • Disconnect 2 flat flexible cables from the formatter.
    • Remove the formatter from the printer.
    • Be careful not to fold, crease, or tear flat flexible cables.
    • The I/O port cover will need to be transferred to the new formatter before installing it.
  13. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Gear: step 13, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Gear: step 13, image 2 of 2
    • Remove the fuser gear by pushing in on the tab with a metal spudger.
  14. HP LaserJet 1160 or 1320 Main Motor Replacement, Tray Connector: step 14, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Tray Connector: step 14, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Tray Connector: step 14, image 3 of 3
    • Disconnect the cable to the tray connector and route it through the hole in the chassis.
  15. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 15, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 15, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 15, image 3 of 3
    • Disconnect 2 cables from the main board and route them through the cable guide.
  16. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 16, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 16, image 2 of 2
    • Remove the cable guide from the chassis.
  17. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 17, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 17, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 17, image 3 of 3
    • Remove the cable guide from the other side of the chassis.
    • Disconnect 2 cables from the main board.
  18. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 18, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 18, image 2 of 2
    • Use needle nose pliers to disconnect the high voltage wire from the fuser.
  19. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 19, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 19, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser Cables: step 19, image 3 of 3
    • Remove the tray connector cable from the cable guide.
    • Disconnect the main motor cable.
  20. HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser: step 20, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser: step 20, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Fuser: step 20, image 3 of 3
    • Remove 3 screws from the right side of the printer.
    • Remove 3 screws from the left side of the printer.
    • The fuser assembly can now be removed from the printer.
  21. HP LaserJet 1160 or 1320 Main Motor Replacement, Midframe: step 21, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Midframe: step 21, image 2 of 2
    • Remove 4 screws from each side of the printer to remove the mainframe.
  22. HP LaserJet 1160 or 1320 Main Motor Replacement, Safety Interlock Assembly: step 22, image 1 of 1
    • Remove 3 screws from the safety interlock assembly (one on top) and remove it from the printer.
  23. HP LaserJet 1160 or 1320 Main Motor Replacement, Feed Plate: step 23, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Feed Plate: step 23, image 2 of 2
    • Remove the feed plate from over the main board.
  24. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board Cables: step 24, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board Cables: step 24, image 2 of 2
    • Remove the tray connector and motor cables from the cable guide.
  25. HP LaserJet 1160 or 1320 Main Motor Replacement, Cable Guide: step 25, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Cable Guide: step 25, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Cable Guide: step 25, image 3 of 3
    • Remove one screw from the cable guide and remove the cable guide from the chassis.
    • Remove one screw from the chassis.
  26. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: step 26, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: step 26, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: step 26, image 3 of 3
    • Remove 2 screws from the left side of the chassis.
    • Push the formatter and safety interlock cables through the hole in the chassis.
  27. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: step 27, image 1 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: step 27, image 2 of 3 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: step 27, image 3 of 3
    • Bend the chassis to allow the control board to come loose, and disconnect the 2 cables from the paper feed assembly.
    • Remove the main board from the printer.
  28. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Board: step 28, image 1 of 1
    • Remove 4 screws on the control board to remove it from its metal plate.
  29. HP LaserJet 1160 or 1320 Main Motor Replacement, Main Motor: step 29, image 1 of 2 HP LaserJet 1160 or 1320 Main Motor Replacement, Main Motor: step 29, image 2 of 2
    • Remove 3 screws to remove the main motor.
jdp23
1,302 Reputation
23 Guides authored
One Comment
hp 1320 printer not running
khurram shahzad - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,254
