HP Laserjet Pro 200 Color MFP Fan Replacement
  1. HP Laserjet Pro 200 Color MFP Fan Replacement, Fan: step 1, image 1 of 2 HP Laserjet Pro 200 Color MFP Fan Replacement, Fan: step 1, image 2 of 2
    • Turn the printer so that the front is facing to your left.
    • Flip the printer so that it is laying with its right side facing down and the bottom facing you.
  2. HP Laserjet Pro 200 Color MFP Fan Replacement: step 2, image 1 of 1
    • Remove the 8 mm screw on the top edge of the printer using a #2 Phillips head screwdriver.
  3. HP Laserjet Pro 200 Color MFP Fan Replacement: step 3, image 1 of 3 HP Laserjet Pro 200 Color MFP Fan Replacement: step 3, image 2 of 3 HP Laserjet Pro 200 Color MFP Fan Replacement: step 3, image 3 of 3
    • There are three tabs along the back right corner of the printer underneath the panel shown (location is displayed in second picture).
    • Use a flathead screwdriver to depress these tabs while lightly pulling the panel towards you.
    • Begin with the upmost tab and move your way down, individually depressing the tabs while simultaneously pulling the panel towards you, removing it from the printer.
  4. HP Laserjet Pro 200 Color MFP Fan Replacement: step 4, image 1 of 1
    • Rotate the printer so you are facing the open side.
  5. HP Laserjet Pro 200 Color MFP Fan Replacement: step 5, image 1 of 1
    • Gently pull out the plug that supplies power to the fan from the socket on the circuit board.
    • Be careful when removing the plug as the components are fragile.
  6. HP Laserjet Pro 200 Color MFP Fan Replacement: step 6, image 1 of 3 HP Laserjet Pro 200 Color MFP Fan Replacement: step 6, image 2 of 3 HP Laserjet Pro 200 Color MFP Fan Replacement: step 6, image 3 of 3
    • There are three tabs that hold the fan in place, as shown in the first picture. These steps may require an extra pair of hands in order to depress all the tabs.
    • Push each tab outwards from the fan.
    • Simultaneously pull the fan towards you until the fan clears the face of the printer.
To reassemble your device, follow the instructions in reverse order.
2 other people completed this guide.
Kendall Gentzen
999 Reputation
5 Guides authored
Cal Poly, Team S9-G14, Maness Spring 2019 Member of Cal Poly, Team S9-G14, Maness Spring 2019
CPSU-MANESS-S19S9G14
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,146
