Introduction
If your HP Laserjet Pro 200 is improperly taking in paper through the bottom tray, you may need to replace your rollers. This guide demonstrates how to quickly replace your printer’s rollers. All you need is a Phillips #2 Screwdriver, iFixit Opening Tool, and Metal Spudger!
Plug in the printer to a wall outlet and place the printer on an accessible surface.
In order to rotate the roller to the maintenance position, a secondary menu must be unlocked via the display.
To unlock this menu, click on Settings tab (the wrench icon in the top left corner).
Once in the Settings menu , quickly click and hold the mid left side of the display (orange square).
While continuing to hold the left side, click the bottom right corner of the display (yellow square) and hold it. This should you bring you right back to the startup menu.
Once again, click on the Settings tab.
3 other people completed this guide.
5 Comments
I can not get the 2ndary Service menu to appear. I have followed these instructions very carefully. Is there another way to access this mennu?
Lord God. This worked just as you instructed. I'm still ready to throw the printer to the curb, but this did work!!
Thank you so much, I reversed the rubber band in the roller and now it worked like new
