HP Mini 110-3735dx Keyboard Replacement
  1. HP Mini 110-3735dx Keyboard Replacement, Battery: step 1, image 1 of 3 HP Mini 110-3735dx Keyboard Replacement, Battery: step 1, image 2 of 3 HP Mini 110-3735dx Keyboard Replacement, Battery: step 1, image 3 of 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Keyboard Replacement: step 2, image 1 of 2 HP Mini 110-3735dx Keyboard Replacement: step 2, image 2 of 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Keyboard Replacement, Backcover: step 3, image 1 of 3 HP Mini 110-3735dx Keyboard Replacement, Backcover: step 3, image 2 of 3 HP Mini 110-3735dx Keyboard Replacement, Backcover: step 3, image 3 of 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Keyboard Replacement, Keyboard: step 4, image 1 of 2 HP Mini 110-3735dx Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Keyboard Replacement: step 5, image 1 of 2 HP Mini 110-3735dx Keyboard Replacement: step 5, image 2 of 2
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Keyboard Replacement: step 6, image 1 of 2 HP Mini 110-3735dx Keyboard Replacement: step 6, image 2 of 2
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Keyboard Replacement: step 7, image 1 of 2 HP Mini 110-3735dx Keyboard Replacement: step 7, image 2 of 2
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Keyboard Replacement: step 8, image 1 of 1
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Keyboard Replacement: step 9, image 1 of 2 HP Mini 110-3735dx Keyboard Replacement: step 9, image 2 of 2
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Keyboard Replacement: step 10, image 1 of 2 HP Mini 110-3735dx Keyboard Replacement: step 10, image 2 of 2
    • Gently pull the keyboard cable from the socket.
Tyrone Williams
923 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 930
