HP Mini 110-3735dx RAM Replacement
  1. HP Mini 110-3735dx RAM Replacement, Battery: step 1, image 1 of 3 HP Mini 110-3735dx RAM Replacement, Battery: step 1, image 2 of 3 HP Mini 110-3735dx RAM Replacement, Battery: step 1, image 3 of 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx RAM Replacement: step 2, image 1 of 2 HP Mini 110-3735dx RAM Replacement: step 2, image 2 of 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx RAM Replacement, Backcover: step 3, image 1 of 3 HP Mini 110-3735dx RAM Replacement, Backcover: step 3, image 2 of 3 HP Mini 110-3735dx RAM Replacement, Backcover: step 3, image 3 of 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx RAM Replacement, RAM: step 4, image 1 of 2 HP Mini 110-3735dx RAM Replacement, RAM: step 4, image 2 of 2
    • Push the two white holders holding the RAM outward until it points upwards at about a 45 degree angle.
  5. HP Mini 110-3735dx RAM Replacement: step 5, image 1 of 2 HP Mini 110-3735dx RAM Replacement: step 5, image 2 of 2
    • Gently pull the RAM from it's socket.
3 other people completed this guide.
Tyrone Williams
923 Reputation
7 Guides authored
1 Guide Comment
Thank you! It was easy!
zeppo1207 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,006
