HP Mini 110-3735dx Screen Replacement
Introduction
Go to step 1If your screen is damaged, flicking, or cracked, use this guide to replace the screen.
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
One Comment
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
