HP Mini 210-1035la Keyboard Replacement
  1. HP Mini 210-1035la Keyboard Replacement, Keyboard: step 1, image 1 of 2 HP Mini 210-1035la Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Shut down the computer
    • Flip the computer upside down
    • Remove the battery by sliding its tabs in and pulling it away from the laptop.
  2. HP Mini 210-1035la Keyboard Replacement, Rubber feet: step 2, image 1 of 1
    • Remove the 4 rubber feet
  3. HP Mini 210-1035la Keyboard Replacement, Removing service cover: step 3, image 1 of 1
    • Simultaneously press in on the right release button (1) to release the right side ofrece the service cover (2)
    • Simultaneously press in on the left release button (3) to release the left side of the service cover (4)
    • Reverse this procedure to insert the service cover
  4. HP Mini 210-1035la Keyboard Replacement, Keyboard's screws: step 4, image 1 of 2 HP Mini 210-1035la Keyboard Replacement, Keyboard's screws: step 4, image 2 of 2
    • Remove the three screws (circled in red) that hold the keyboard
    • With the computer facing you, turn it right-side up.
    • Completely open the computer
  5. HP Mini 210-1035la Keyboard Replacement, Remove keyboard: step 5, image 1 of 3 HP Mini 210-1035la Keyboard Replacement, Remove keyboard: step 5, image 2 of 3 HP Mini 210-1035la Keyboard Replacement, Remove keyboard: step 5, image 3 of 3
    • Lift the back edge of the key board until it rest at an angle
    • Slide the keyboard back until the keyboard cable and connector are accessible
    • Release the connector to which the keyboard cable has been attaching, and then disconnect the keyboard cable
    • Remove the keyboard
3 other people completed this guide.
Internet Libre
740 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,537
