HP Mini 210-1199DX RAM Replacement
  1. HP Mini 210-1199DX RAM Replacement, Battery: step 1, image 1 of 2 HP Mini 210-1199DX RAM Replacement, Battery: step 1, image 2 of 2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX RAM Replacement: step 2, image 1 of 1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX RAM Replacement, Bottom Cover: step 3, image 1 of 1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX RAM Replacement: step 4, image 1 of 3 HP Mini 210-1199DX RAM Replacement: step 4, image 2 of 3 HP Mini 210-1199DX RAM Replacement: step 4, image 3 of 3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX RAM Replacement: step 5, image 1 of 1
    • Pull the case off of the device
  6. HP Mini 210-1199DX RAM Replacement, RAM: step 6, image 1 of 1
    • Locate RAM systems.
  7. HP Mini 210-1199DX RAM Replacement: step 7, image 1 of 1
    • Use spudger to carefully pull the holding devices back.
    • RAM should pop out once this is completed.
  8. HP Mini 210-1199DX RAM Replacement: step 8, image 1 of 1
    • Carefully pull the RAM card out.
Phillip Winston
655 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 341
