HP Mini 311 Battery Replacement
  1. HP Mini 311 Battery Replacement, Battery: step 1, image 1 of 3 HP Mini 311 Battery Replacement, Battery: step 1, image 2 of 3 HP Mini 311 Battery Replacement, Battery: step 1, image 3 of 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 Battery Replacement: step 2, image 1 of 2 HP Mini 311 Battery Replacement: step 2, image 2 of 2
    • Slide the battery away from the device to remove.
6 other people completed this guide.
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 2,222
