HP Mini 311 Memory Shield Replacement
  1. HP Mini 311 Memory Shield Replacement, Memory Shield: step 1, image 1 of 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  2. HP Mini 311 Memory Shield Replacement: step 2, image 1 of 2 HP Mini 311 Memory Shield Replacement: step 2, image 2 of 2
    • Lift the memory shield up and remove from the laptop.
Christian Santoyo
495 Reputation
6 Guides authored
Cal Poly, Team 20-4, Maness Winter 2013 Member of Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 865
