HP Notebook 15-db003ca RAM Replacement
  1. HP Notebook 15-db003ca RAM Replacement, RAM: step 1, image 1 of 1
    • Place the powered-off laptop on a clean workspace.
  2. HP Notebook 15-db003ca RAM Replacement: step 2, image 1 of 1
    • Flip the laptop over such that the backside of it is facing you.
    • Grab a Phillips #1 screwdriver.
  3. HP Notebook 15-db003ca RAM Replacement: step 3, image 1 of 1
    • Remove the four 9 mm screws from the back panel using a Phillips #1 screwdriver.
  4. HP Notebook 15-db003ca RAM Replacement: step 4, image 1 of 3 HP Notebook 15-db003ca RAM Replacement: step 4, image 2 of 3 HP Notebook 15-db003ca RAM Replacement: step 4, image 3 of 3
    • Peel the two strips to uncover more screws.
    • Place the strips near where they were removed.
  5. HP Notebook 15-db003ca RAM Replacement: step 5, image 1 of 2 HP Notebook 15-db003ca RAM Replacement: step 5, image 2 of 2
    • Remove the remaining seven 9 mm screws using a Phillips #1 screwdriver.
  6. HP Notebook 15-db003ca RAM Replacement: step 6, image 1 of 3 HP Notebook 15-db003ca RAM Replacement: step 6, image 2 of 3 HP Notebook 15-db003ca RAM Replacement: step 6, image 3 of 3
    • Remove the back panel and locate the RAM stick.
  7. HP Notebook 15-db003ca RAM Replacement: step 7, image 1 of 2 HP Notebook 15-db003ca RAM Replacement: step 7, image 2 of 2
    • Push the RAM to remove it from its slot like shown in the picture.
    • When reassembling, ensure the memory is inserted into the slot and pushed until it clicks into place.
2 other people completed this guide.
vtsn t
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 36
All Time: 729
