HP Officejet 4630 Fax Feeder Replacement
  1. HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: step 1, image 1 of 2 HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: step 1, image 2 of 2
    • Lift the fax feeder cover until it stands on its own.
  2. HP Officejet 4630 Fax Feeder Replacement: step 2, image 1 of 3 HP Officejet 4630 Fax Feeder Replacement: step 2, image 2 of 3 HP Officejet 4630 Fax Feeder Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to unclasp the hinge that holds the feeder cover.
  3. HP Officejet 4630 Fax Feeder Replacement: step 3, image 1 of 2 HP Officejet 4630 Fax Feeder Replacement: step 3, image 2 of 2
    • Lift the green tab to remove the fax feeder from the printer.
  4. HP Officejet 4630 Fax Feeder Replacement: step 4, image 1 of 3 HP Officejet 4630 Fax Feeder Replacement: step 4, image 2 of 3 HP Officejet 4630 Fax Feeder Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to pry the pivot point apart while lifting the feeder up.
    • There is still a cable holding the part to the rest of the printer.
  5. HP Officejet 4630 Fax Feeder Replacement: step 5, image 1 of 2 HP Officejet 4630 Fax Feeder Replacement: step 5, image 2 of 2
    • Use a screwdriver to remove the single 9mm T10 screw.
    • Remove the wire cover and pull the wire away from the printer. The fax feeder head is now free to be separated from the printer.
2 other people completed this guide.
Isaac Jacobsen
585 Reputation
1 Guide authored
Cal Poly, Team S18-G3, Livingston Winter 2018 Member of Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Members
18 Guides authored
One Comment
I am so glad i found this site…I was able to unjam a lease that had gotten stuck…..thank you thank you7… times over…Lee
Lee Shankle - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,081
