HP Officejet 4630 Scanner Head Replacement
  1. HP Officejet 4630 Scanner Head Replacement, LCD Display: step 1, image 1 of 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: step 1, image 2 of 3 HP Officejet 4630 Scanner Head Replacement, LCD Display: step 1, image 3 of 3
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 Scanner Head Replacement: step 2, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 2, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 2, image 3 of 3
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 Scanner Head Replacement: step 3, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 3, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 3, image 3 of 3
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 Scanner Head Replacement: step 4, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 4, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 4, image 3 of 3
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  5. HP Officejet 4630 Scanner Head Replacement, Power Supply: step 5, image 1 of 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: step 5, image 2 of 3 HP Officejet 4630 Scanner Head Replacement, Power Supply: step 5, image 3 of 3
    • Lift the hood of the printer.
  6. HP Officejet 4630 Scanner Head Replacement: step 6, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 6, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 6, image 3 of 3
    • Remove the two T10 11mm screws.
  7. HP Officejet 4630 Scanner Head Replacement: step 7, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 7, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 7, image 3 of 3
    • Remove the panels covering the power brick and cord.
  8. HP Officejet 4630 Scanner Head Replacement: step 8, image 1 of 2 HP Officejet 4630 Scanner Head Replacement: step 8, image 2 of 2
    • Remove the cord from the power supply.
  9. HP Officejet 4630 Scanner Head Replacement: step 9, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 9, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 9, image 3 of 3
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  10. HP Officejet 4630 Scanner Head Replacement: step 10, image 1 of 1
    • Remove final cable from power supply.
  11. HP Officejet 4630 Scanner Head Replacement, Scanner Head: step 11, image 1 of 1
    • Remove eight T10 1mm screws from the top hood of the printer.
  12. HP Officejet 4630 Scanner Head Replacement: step 12, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 12, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 12, image 3 of 3
    • Use the nylon spudger to pry the tab.
    • Lift up the entire panel.
  13. HP Officejet 4630 Scanner Head Replacement: step 13, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 13, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 13, image 3 of 3
    • Lift and flip the entire panel.
    • Be aware of the scanner head attached to the panel.
  14. HP Officejet 4630 Scanner Head Replacement: step 14, image 1 of 3 HP Officejet 4630 Scanner Head Replacement: step 14, image 2 of 3 HP Officejet 4630 Scanner Head Replacement: step 14, image 3 of 3
    • Start with the scanner head in place.
    • Unwind the ribbon from the track.
    • Detach ribbon completely.
Maya Willis
415 Reputation
3 Guides authored
Cal Poly, Team S18-G3, Livingston Winter 2018 Member of Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 1,460
