HP Officejet J4550 All-in-one Glass Plate Replacement
Jiayin Zhu
Jiayin Zhu and 2 other contributors
Last updated on May 4, 2023
20 - 25 minutes
Moderate
Introduction
Go to step 1
Is the glass plate in your printer broken? Consider using this guide to replace the glass plate in your printer.
Tools
  1. HP Officejet J4550 All-in-one Glass Plate Replacement, Glass Plate: step 1, image 1 of 2 HP Officejet J4550 All-in-one Glass Plate Replacement, Glass Plate: step 1, image 2 of 2
    • Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Using fingers to open the cover of the scanner which located on the top of the printer.
  2. HP Officejet J4550 All-in-one Glass Plate Replacement: step 2, image 1 of 3 HP Officejet J4550 All-in-one Glass Plate Replacement: step 2, image 2 of 3 HP Officejet J4550 All-in-one Glass Plate Replacement: step 2, image 3 of 3
    • Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove the cover of the top part.
  3. HP Officejet J4550 All-in-one Glass Plate Replacement: step 3, image 1 of 3 HP Officejet J4550 All-in-one Glass Plate Replacement: step 3, image 2 of 3 HP Officejet J4550 All-in-one Glass Plate Replacement: step 3, image 3 of 3
    • Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver.
    • Remove the back board of the controlling keyboard.
  4. HP Officejet J4550 All-in-one Glass Plate Replacement: step 4, image 1 of 2 HP Officejet J4550 All-in-one Glass Plate Replacement: step 4, image 2 of 2
    • Remove the controlling keyboard with hands.
  5. HP Officejet J4550 All-in-one Glass Plate Replacement: step 5, image 1 of 2 HP Officejet J4550 All-in-one Glass Plate Replacement: step 5, image 2 of 2
    • Using fingers to open the back cover board of the glass plate.
  6. HP Officejet J4550 All-in-one Glass Plate Replacement: step 6, image 1 of 3 HP Officejet J4550 All-in-one Glass Plate Replacement: step 6, image 2 of 3 HP Officejet J4550 All-in-one Glass Plate Replacement: step 6, image 3 of 3
    • Remove the 10mm screw on the right of the board with T8 torx security screwdriver.
    • Remove the part that is under the 10mm screw.
  7. HP Officejet J4550 All-in-one Glass Plate Replacement: step 7, image 1 of 2 HP Officejet J4550 All-in-one Glass Plate Replacement: step 7, image 2 of 2
    • Remove the glass plate with hands.
Jiayin Zhu
376 Reputation
3 Guides authored
UC Davis, Team S11-G8, Lore Fall 2018 Member of UC Davis, Team S11-G8, Lore Fall 2018
UCD-LORE-F18S11G8
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 207
