HP Officejet Pro 6835 AC Power Adapter Replacement
  1. HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: step 1, image 1 of 3 HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: step 1, image 2 of 3 HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: step 1, image 3 of 3
    • Use a T9 torx screwdriver to remove one (1) 10mm screw by turning it counterclockwise.
    • Grab the backplate and pull it towards you to remove it.
  2. HP Officejet Pro 6835 AC Power Adapter Replacement: step 2, image 1 of 1
    • Grab the AC Power Adapter and pull it towards you to slide it out.
  3. HP Officejet Pro 6835 AC Power Adapter Replacement: step 3, image 1 of 1
    • Grab the base of the colored, braided cable and pull it out of the AC Power Adapter.
Jake Park
465 Reputation
2 Guides authored
Cal Poly, Team S2-G4, Livingston Winter 2018 Member of Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 720
