HP Officejet Pro 8600 Plus Battery Replacement
  1. HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: step 1, image 1 of 2 HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: step 1, image 2 of 2
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Battery Replacement: step 2, image 1 of 1
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Battery Replacement: step 3, image 1 of 1
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Battery Replacement: step 4, image 1 of 2 HP Officejet Pro 8600 Plus Battery Replacement: step 4, image 2 of 2
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Battery Replacement: step 5, image 1 of 1
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Battery Replacement: step 6, image 1 of 1
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
  7. HP Officejet Pro 8600 Plus Battery Replacement: step 7, image 1 of 1
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  8. HP Officejet Pro 8600 Plus Battery Replacement: step 8, image 1 of 3 HP Officejet Pro 8600 Plus Battery Replacement: step 8, image 2 of 3 HP Officejet Pro 8600 Plus Battery Replacement: step 8, image 3 of 3
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
  9. HP Officejet Pro 8600 Plus Battery Replacement, Battery: step 9, image 1 of 2 HP Officejet Pro 8600 Plus Battery Replacement, Battery: step 9, image 2 of 2
    • Turn the motherboard over so the back is facing upward.
    • Use the plastic opening tool to pry the battery out of place.
  10. HP Officejet Pro 8600 Plus Battery Replacement: step 10, image 1 of 1
    • Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
9 other people completed this guide.
Mackinnon Buck
1,182 Reputation
3 Guides authored
Cal Poly, Team S16-G4, Livingston Spring 2018 Member of Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 Members
10 Guides authored
2 Comments
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - Reply
Bonjour ,
ma batterie est ok , par contre la courroie s'effiloche.
Peut on la remplacer et si oui comment y accéder?
J'ai déplacé le tendeur pour augmenter la tension de la courroie mais ce n'est pas suffisant.
Merci
BàV phil
Philippe Herbots - Reply
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 62
All Time: 5,287
