HP Officejet Pro 8600 Plus Front Panel Replacement
  1. HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: step 1, image 1 of 2 HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: step 1, image 2 of 2
    • Open the front panel door by pulling forward on the slot located on the front-left side of the printer.
  2. HP Officejet Pro 8600 Plus Front Panel Replacement: step 2, image 1 of 2 HP Officejet Pro 8600 Plus Front Panel Replacement: step 2, image 2 of 2
    • Insert the plastic opening tool into the right socket connecting the front panel door to the hinge guide.
    • Pry the socket open, lifting the door hinge guide out of place.
  3. HP Officejet Pro 8600 Plus Front Panel Replacement: step 3, image 1 of 2 HP Officejet Pro 8600 Plus Front Panel Replacement: step 3, image 2 of 2
    • Pull the door-hinge guide to the right to detach its left socket.
    • Lift the door-hinge guide upward and away from the front panel door.
  4. HP Officejet Pro 8600 Plus Front Panel Replacement: step 4, image 1 of 2 HP Officejet Pro 8600 Plus Front Panel Replacement: step 4, image 2 of 2
    • Grab the front panel door close to its hinge on the right side.
    • Pull the front panel door away from the printer toward you.
    • Extra force may be required to pull the door from its hinge.
  5. HP Officejet Pro 8600 Plus Front Panel Replacement: step 5, image 1 of 3 HP Officejet Pro 8600 Plus Front Panel Replacement: step 5, image 2 of 3 HP Officejet Pro 8600 Plus Front Panel Replacement: step 5, image 3 of 3
    • Grab the front panel door close to its two hinges on the left side.
    • Extra force may be required to pull the door from its hinges.
2 other people completed this guide.
Maegan Betz
301 Reputation
1 Guide authored
Cal Poly, Team S16-G4, Livingston Spring 2018 Member of Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 3,733
